Hi guys
Now have a hi-flow so don't need the stock turbo anymore.
Done about 80,000km's... Boost at 10-11psi for the last 15-20K km's.
Always tried to look after it as best as possible, ie, waiting for oil to get to the right temp, letting the car cool down after driving, etc. Royal Purple synthetic oil used, change about every 7.5K km
Turbo change was done at Status Tuning, Trent said the turbo was absolutely fine. I don't know much about turbo's or what to look for, so i made sure to ask him what he thought of it when it came off the car.
Price: $450
Great upgrade for R32, and even R33. Or Hi-flow if you want.
Pics
cheers,
daniel
https://www.sau.com.au/forums/topic/259303-r34-neo-turbo/
like i said before, tentative sale...
back on market. $450 delivered anywhere in oz. no point low balling because i know it's a good turbo and i have a few people around the mark. I'm not going to jack the price because of the interest, i'm just going to sell it for what i first posted it at.
whoever meets the price first, has it
good luck
https://www.sau.com.au/forums/topic/259303-r34-neo-turbo/#findComment-4499844
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
