Hi All,
Ive had this anoying sqeak for the past week or so only notice it when im going slow and theirs minimal road noise (under say 40km/h). Tonight decided to investigate it a bit more. Ive worked out that when I push down on the Passenger front guard to compress/move suspension it makes the sound.
I removed the wheel and sprayed some inox on the any moving parts i could see to see if somethings just super dry or whatever and then put the wheel back on and had another push and the f**kers still their. :blink:
If i was to remove the coilover and completely remove all the suspension components lube them up and re install will I loose any camber or toe/alignment settings?
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/259315-anoying-sqeak-from-front-left/
Any ideas?
Yeah, you'll need a re-alignment if you remove your coilovers.
I'd say it could be one of your bushes...camber, castor, or swaybar bushes.
I put this up in the stag section as well and their are two others that had the same problem.
For both of them they removed a bolt on the control arm pryed back the seal on the bush with a flat head screwdriver and sprayed some lube in each end and it shut the thing up.
Start uni late tomorrow so will give it a crack :P
haha no GF at the moment. But i do have a funny story...
Took a girl for a drive down to the bay a few weeks back to go for a walk around the place icecream and walk on the beach ect (early stages of getting in her pants ayy :P)
On the way down their on anzacs a black VE V8 commie of some sort pulled up next to us with 4 male occupants and the driver put down his window and said Ill race you for your missus. HAHA she WASNT impressed and put the window up almost immediately.
being used as a wager hahahah....
Best part was I was to busy laughing about it and completely missed the lights as the commie rocketed away.... haha
i think its a decoy from those commy drivers...
make you laugh so hard that you miss the lights and they can scamper away
lol
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
