I need ur recommendations on a workshop to tune my safc.
I've called a few places and the prices vary heaps, some are ridiculous!
This is what I've asked for when calling:
I have a R33 GTS-T, 3" turbo back exhaust, 12psi, and a different filter. I would like a price for tuning an already installed Apexi SAFC on the dyno please. (there's my scripting for the day :) )
So far my quotes are:
Hills Motorsport $600 ---- WTF????
Croydon $400-450--- another WTF????
BD4s $135-145 (not too bad..)
Obviously Hills and Croydon have no idea what they're talking about.
Can anyone recommend somewhere else in sydney? I'm from Parra area but can travel to Penrith or East no problems.
Thanks in advance.
Same as melbourne.. there is places that will charge you $400 (not mentioning names) to do what another would charge you $100 for. Pays to shop around, but I'd say that last one seems best if you ask me.
I've had a really expensive tune, and a cheaper one - noticed no difference in the end results.
Spare a thought for us canberrens, Nobody here can touch any HKS / Apexi / Jap stuff confidently.. Only Microtech / Digitech..
Go with Silverwater or BD4's - I hear good things about them.. Bd4's quoted me 250 - 1000, (and possibly a week) to fully tune My HKS F-CON V Pro... (Still havent got around to it)
But the different quotes *must* be for different amounts of work, right?
Well I hope not! I have asked all of the companies the same questions. I didn't add or take from the job mentioned above, that way I can compare quotes for the same amount of work. I suppose some of them are either dumb ie. don't know what an safc is and are too afraid to ask so they over quote to get rid of me, or they're just plain rip-offs!
Thanks T0nyGTSt, I called Unigroup first as they're only 5mins from my house, but no one was there so I left a msg. Meanwhile ProCar at DeeWhy (yes, it's a fair hike) called me back and gave me a reasonable quote of $125 or under. The guy on the phone was nice and seemed to know what he was talking about compared to the other companies mentioned above (except for BD4s) so i booked in for saturday after next :rofl:
Hi firebladejr, in Sydney dyno time is around $120 per hour. So, using your $145 quote, if you allow for loading, tie down, sensor fitting, dyno parameter set up, unloading etc there is only around 40 to 45 minutes available to tune the SAFC. Now if you know what you are doing you can tune the SAFC pretty well in that time. But I wouldn't expect anything else, no time to do stuff like check the fuel pressure, adjust the ignition timing, check the boost stability, check to make sure there is no problems with the A/F ratios in excessively hot or cold conditions, hot start, cruise fule economy, idle stability with a/c on etc etc.
Pay $145 to tune the SAFC and that is exactly what you will get, not one thing more. But, personally, I would want to optimise the performance available from the correct A/F ratios achieved by fitting the SAFC. I would want them to check if I could sneak a bit more boost, if I could advance the ignition timing, if there was a fuel pressure problem (pump failing), if the boost controller was holding stable under all conditions etc etc. I would also want to make sure there was not going to be any problems under a wide range of conditions.
So maybe the low quote was ONLY for tuning the SAFC, nothing else and the higher quotes were allowing for a (what I would consider reasonable) level of care and improved performance above that.
I'd like a dollar for every time someone has told me to ONLY do "X", and then come back when "Y" fails and ask me why I didn't check that as well.
Maybe you should ask them a few more questions.
Firebladejr,
I'm very interested to read your comments on how you go with getting your S-AFC tuned. I'll be getting an S-AFC II in about a month. I'll be looking for someone to fit and tune the thing for me.
I've dealt with Rick Shaw in the past. The service was good and the prices were very reasonable. I'm just not sure how much they know about Apexi products or tuning them correctly.
I have also dealt with BD4's as well. The service was so-so but they were abit pricier than Rick Shaw. Again...how well do they know Apexi products? I know they use alot of HKS products though.
I've always heard good things about BD4's and $145 sounds like a good price, seeing as they have tuned some serious cars previously.
Wouldn't recommend hills motorsports though,ESPECIALLY AT $600! pm for further details if interested.
I paid $150 for my S-AFC tune at Hills a couple of months back. It took around 2 hours (he did have to leave the job for a few minutes every now and then to tend to other stuff though) and it involved adjusting the timing. Are you sure they didn't think you were referring to a PowerFC tune? I understand that they can cost upwards of $500. Also, the last time I got a quote from CRD they quoted me $200 or so. But that was almost a year ago.
Firebladejr,
I got my powerFC tuned at Procar in Dee Why. They set up my fuel system (I had a fuel pump and regulator installed a few days prior to the tune).
The guy who tuned it took about 4 hours on the dyno whilst I sat in the passenger seat watching the engine check light for him while he did his maths and explained what he was doing.
After he was happy with the tune he reduced the timing by 2 and set a safety net somehow so if the powerfc notices very very unlikely readings it will handle things so the engine doesn't blow.
I requested that the tune had to be on the safe side becuase I havent got the $$ to buy another engine in 6 months time. He told me he does this to every job.
bbenny is another to ask on the forums about procar. He has a HKS powered R32 and has used procar for a dyno run. I think he was getting a safc tuned there are well.
Mark
Originally posted by MRK25T
Firebladejr,
I would like to know what this is since I was under the impression the PFC doesn't have any Detenation controlled timing retard....
Firebladejr,
Thats what he told me, i've got no idea if its true or false - it sounded safe to me so I was happy.
Mark
i got my safc tuned on the road by my mech.. $10
to me i feel being tuned on the road is a little more realistic as there are things like cold air etc etc....
also they way u drive it
im happy with my $10 spent
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
