Hmm....
i may be in UK @ the Mo, but these 2 punks are NOT the only grey series I's in perth. (Even though its not mine :mad:)
young bloody whipper snippers....
P:S as i'm in a internet cafe and can't be bothered waiting for page reloads... can someone pls register interest on MC motorsport team type thingo....
3 weeks here and seen 1 R34 1 R33 (gtr) and 1 4 dr R32.
more when i come back..piccies too :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
