hi cassbo
some wag suggested maybe your firewall has flexed a loooong way on previous track days hence the closeness of the fit.
i would make sure you give a bit of a tighten up and check it regularly for the first few weeks in case there is any truth to this rumour and the firewall moves back a bit. :banana:
Edited by wolverine
  • Replies 75
Posted Images
Latest update:
1. Wolverine : Paid & Delivered
2. Sheng : Paid & Collected
3. Victory : Paid & Delivered
4. Wisey18 : Payment Due End of Month
5. Raps86: Paid & Ready for Collection
6. R34GTFOUR : Paid & Delivered
7. Cassbo : Paid & Collected
8. DaveB : Paid & Delivered
9. BensDR30 : Payment Pending
10. N-Dawg : Paid &Delivered
11. Rocketboy : Pm sent re-delivery costs
12. RobMz : Paid & Delivered
13.
14.
Latest update:
13. [ANGRY13] : Payment Pending
14. purpleisafruit : Payment Pending
15.
16.
is there any method to setting these things up? you don't need one person in the car and one person installing do you??
Just remove the plastic bits covering the recessed holes on the strut tower, attach the plate, put in the bolts and tighten, screw in the bolt against the master cylinder with the flange on the end. After driving check the bolts again later if they need further tightening. Based on what I've read on other forums in regards to brake stopper installation.
My main question is how tight to press up against the master cylinder? even when tightening the big bolt all the way there's a tiny bit of play between then MC and the bolt flange. Should this be pressed right up against the MC?
I've noticed the difference under heavier braking. At the moment my brakes have been quite soft (almost having to put pedal to floor sometimes, it's booked in for new rotors n pads this week and a check of the braking system) but meanwhile this master cylinder has given more confidence with braking the way that it currently is.
If you open the bonnet, put one foot in the car pressing down on the brake (with the car on) and have a look at the movement of the master cylinder you can see how much flex there is. I was quite suprised with mine actually.
almost out of stock until the next lot are made which is approximately 4-6weeks. there may be only one or two left.
Latest update:
5. Raps86: Paid & Delivered
9. BensDR30 : Paid & Ready for Delivery
13. Latinaso : Paid & Delivered
14. [ANGRY13] : Paid & Ready for Delivery
15. purpleisafruit : Paid & Ready for Delivery
16.
Edited by wolverine
yeah, that's what i meant be "setting up" :)
Latest update.
9. BensDR30 : Paid & Delivered
11. Rocketboy : Pm sent re-delivery costs (presuming not interested due to lack of response to pm).
14. [ANGRY13] : Paid & Delivered
15. purpleisafruit : Paid & Delivered
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
