Geebuz - just when I think I've got my fuel issues under control I find out the fuel guys are only at the lunch stops on day 1 and 2.
So thats 114km to lunch on day 1 (ok) - 217km's after lunch (no hope)
195km's to lunch on day 2 and then 232km's after lunch (all no hope!)
How the hell do the rest of you get so far on a tank of fuel!!!?
There is an extra refuel zone in the afternoon on Day 1 and extra zones in the morning and afternoon on Day 2 - but if the refuel mobs aren't there (and there are no 98 stations) how are you supposed to do fuel regardless unless you have your own crew?
  • Replies 652
Posted Images
jerry can
Day 1. You'll get to lunch day 1 no worries, first coupla stages are just easy driving warm ups.
You'll need a splash at the fuel stop in the afternoon of day 1.
Day 2. We normally get a splash somewhere after The Sideling. Normaly at the intersection either side of Ledgerwood is a good spot with plenty of room. Then another splash at St Helena from memory (I think there's a pump there?).
There's a big long touring stage down to Elephant Saddle, and from memory the boys cut through there to give us more after it which saw us through to the end of the day. I remeber some were also having a slash after Rossarden too.
Have the guys who are fueling you actually done it before?
day 2 we fill after the sidling in scotdale, then in st helens.
day 5 is going to be the hard day on fuel. need to fill up at queenstown, and after arrowsmith.
i don't think your allowed to carry fuel in the car this year?
This is the Elf Race-fuels fuel service that only has stops on Day 1 and 2 at lunch!! I think they call themselves Performance Tyres and Fuels down in Tassie.
That's who I was planning on using for fuel but it seems they will only half help me!
This is the list I've been given today of where they'll be.
LEG 1 = ON ROUTE – Beaconsfield Sports Ground - Silverdome
LEG 2 = ON ROUTE - St Helens (Esplanade) - Silverdome
LEG 3 = ON ROUTE – East Devonport Rec Ground - Refer road book
then Silverdome
LEG 4 = ON ROUTE – Erriba (after Cethana) - Penguin Sports Center -
Tullah (after Township) - Strahan (Esplande)
LEG 5 = ON ROUTE – Queenstown (end of Strahan Stage)- Derwent Bridge after Mt Arrowsmith
Oh good - sounds like everyone is going to run out of fuel then with me :P
Fuel is only a problem on Day 5 normally. Not sure on the GTr, but if you need xtra get your service crew to take it. You do have a service crew?
We normally split the crew on day 5... one car on weekend only duty heads for the top of the mountain.
do the 34's use worse than the 7/2km/ltr or do they have a small tank?
TT
Just to confirm fuel consumption from last year is as follows:
Starting with a full tank
Day1: 49.5 litres at lunch break, 44.8 litres end of day = 94.3
Day 2: 20 litres at Legerwood, 42 litres at St Helens lunch break, 20 litres after Rossarden, 38 litres end of day = 120
Our competitive fuel consumption really didn't start to get bad till day 4/5 with those longer open stages with long periods of WOT and long transports.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
