Hi,
I'm looking to complete my HKS drager exhaust and trying to find a dump/front pipe. I found this HKS Polished Front Pipe from Nengun but I can't seem to get a reply from them if this is actually a dump AND front in one as the pictures seem to show that it is.
Has anyone got one or know what this is all about? Also, from the looks of the picture are these bellmouthed? I would prefer to have the bellmouth design since I can't find a good place to make me a split system and from the way things are looking I'll probably end up keeping my car for awhile and surely will change turbo in the future when I get bored.
http://www.nengun.com/hks/polished-front-pipe
Hopefully that link works.
Any help would be great.
https://www.sau.com.au/forums/topic/259705-hks-polished-front-pipe/
Its just a front pipe. Bolts to the OEM dump pipe.
I have the Mild steel version on my R33.
Stainless one is expensive! But i do want the HKS dump pipe too. Would prefer that in mild steel also... but sheet it is dear!
who has used www.rhdjapan.com, they have decent prices, unlike nengun who want to charge $200 delivery for everything
Just want to know who has had experience with www.rhdjapan.com and are they good? reliable?
Interesting you say that, as everything i have bought from Nengun has been miles cheaper than RHD.
For example i was looking at the HKS dump pipe, its a good $60 cheaper than RHD..
Other than that, mates have used it and never had a problem.
Thanks heaps for the replies guys! Guess the search continues, maybe I should just fork up the cash and get the HKS split dump extension and then the front pipe haha I always believe you get what youy pay for and I would LIKE to believe I'm paying more for less hassles later on.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
