He is sore because his scam/false advertising has been found out. It is now publically known that he can't be trusted, and has lost alot of potential business nationally.
If evidence could be provided and he was up front and honest, plus treated people with some manners then I would believe he is a true business person. But his wording and manners suggest that he has obviously been short changed in the IQ department, especially thinking he could scam an Skyline car forum that he actually has a legit NISMO tunned/built engine in a GTR.
If he was serious, then paper work, dates of work done, updates to FAST and NISMO themselves would be able to verify the said car. Alas this has not been case, and as a business person I would have expected you to have fully researched the vehicle before importing or selling. So in the end it sux to be u!
  • Replies 197
Ok just to sum up incase I've missed something:
Question asked about a guy selling a car with a "NISMO Built engine". Turns out the guy selling the car can't back up anything... THEN has a go at everyone because we found it to not be NISMO built?
Have I missed something here???
Well screw it I'll have a go - I'm selling an R34 GTR V-Spec II Nur - it looks surprisingly like an R32 GTSt but trust me it has the number 2 in the engine number so it's a R34 GTR V-Spec II Nur ...
Anyone who says I'm wrong is a "tosser"
Good job Jim, good job.
tossers everwhere just as i thought , makes this fourm a tosser site ! should be tossers austrilia , not skylines austrailia
So Jim, you wont be posting here any more?...sounds like a great idea. :)
BTW It's Australia not "austrilia"
Clost this thread? Why would we want to do that now? Think I might leave it open a little longer sorry. You've been caught out trying to spin sh|t and now you're just dark you've been caught.
Mate if this is a tosser forum, why don't you "toss along" now and try and shaft some drift kiddies somewhere huh?
So you stated to the potential buyer that it was an S-Tune engine because it had an "S" in the engine number, then you claim that
"R33 GTR V-spec nismo Japan Built engine ,nismo Twin turbos, 4WD Special mid night purple duco RARE"
So are Nismo changing engine numbers now or are you completely FOS, actually by your previous comments you don't have to answer that.
Edited by D_Stirls
And here i was, reading boost like the good little enthusiast i am, and had much respect for OH Performance for building 2 very very awesome GTR's. And to find out, well, all of the above?
BAHAHAHAHAHAHA :/
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
