  • Replies 89
might send the young lady along for abit of fun
oh hang on u weren't referring to yourself..... :/ Okay then send the missus along while u sit at home drinking home brew!!! :)
Paid..........looking forward to seeing you all.
i rrreeeaaallllllyyyy wanna check out all your hard work flying a zillion miles an hour down the straight!! Should look/sound bloody awesome!! :D
Should be an awesome day! Good pre-practice for Round 3 of SSCC :)
i see that you and weevil have been getting some practice in, you guys will be instructing with Bozy by May.
Small hijak guys but does anyone know how to track down SAU NSW membership progress.
I mailed mine off and payed about 6 weeks ago and havent heard anything, have also sent PMs and emails. Want to get it sorted as to get Cams liscence. Any help would be appreciated.
i rrreeeaaallllllyyyy wanna check out all your hard work flying a zillion miles an hour down the straight!! Should look/sound bloody awesome!! :)
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
