If you were in Brisbane I can bench test them for you.
I don't know anyone in Melbourne with the same equipment. There are resistance checks you can do as above was suggested but even they can be misleading at times.
r33 s2, car is missfiring above 4000 revs i regaped my plugs to 0.8 and it fixed the problem for about an hour and now its back to missfiring, i taped the stock coils up wit electrical tape aswel. so since spark plugs only worked as a temproary fix im assuming changing my coil packs will fix the problem what do you guys think?
It's a possibility man.
Mine was doing something similar to this and when I changed to Splitfires, the problem was solved. Mine was breaking up above 4000rpm on 7lb, and at 3500rpm on 22lb of boost, and she was spewing a shitload of black smoke.
Whether your issue is the same or not can only be discovered through a process of elimination.
I have seen many questions asked regarding this through the forums and there have been several different courses of action taken. Some have had ECU, TPS, spark plug etc issues.
Do a search and you will find what the other guys were discovering, and that will help you to get to the root of your problem.
when your std coils are dead they work fine and then one day they just start to misfire city when the engine is on load/boost
replacing plugs etc doesnt fix the issue as the coils are breaking down. mine died at 160,000kms and replaced with splitfires no issues after that
if its happened all of a sudden and youve put in new plugs then yeah coils are toast - they die sooner or later
ahh k i see, well i got some more information ive noticed now its missfiring only when its cold like early in the morning when the weather is warmer its fine, is this also sign of coils? just wanting make sure before i got and spend 600
I got a set of these a couple of weeks ago and they are great. http://www.skylinesaustralia.com/forums/Co...80&start=80
Only cost me $350 with post and they are about to release the series 2 versions also.
im pretty sure as well that higher up the rpm the voltage to the coils drop which will make the car miss. you have to run a relay to the coils which will give it constant power. well thats wat im going to try with my ceffy.
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
