  • Replies 589
Things are looking great this morning.
Will pull out the deep crystal 3 step thing from Meguairs and start working on the babe.
In terms of admin stuff, I've got the flyers ready and Excel spreadsheet set up - just need a BEAUTIFUL sunday morning now!
Could be out. Car won't start. Battery is f***ed! :) Anyone have one they could lend me?
Got a spare loaner battery N66 with rating:585CCA in good cond... but...
size is 17.5cm width, 27cm long, 18cm high
It came out of a 6 cyl BMW
...and it's at Springwood, if you want to bring your Ford to pick-up.
Best I can do atm.
Tez
That reminds me Shanil that whilst the weather report is: FINE & WINDY tomorrow, remember that...
If Sydney temp is 21, Mt Wilson temp will be 16. And then take 2 more degrees off as wind factor = 14.
Take a jacket!
Meguiars Step 1 paint cleaner complete.
begin step 2 polish in 20 minutes when arms can be bothered again.
one query - do i need to wash my car again in between step 1 and step 2?
The babe has been cleaned, polished, waxed, vacuumed, tyre shined, and window cleaned.
A good 6 hours of work has finally paid off!
Can't wait until tomorrow.
just vacuumed, washed and tyre shined car!
downside it's still dirty haha oh wells
Calsonic14u: you wont happen to live around mosman or northern beaches way? sometimes see this blue r33 around the area
Car is washed, inside and out - to the best of my concentration and strength anyways! Doesn't look too shabby but definitely won't be winning any Best Exterior prize!
Anyone heading up from the North Shore or Northern Beaches? Missus and I wouldn't mind some buddies on the way to Penrith. We're planning a 8 to 815 departure to make the 930 meet. Have to take it easy, fuel will be an issue tomorrow!
Sorry guys, got caught up at the shopping centre.
Based on today's weather in Sydney and the above stated forecasts, the event tomorrow is going ahead!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
