Has anyone had their guards rolled, or lipped, or whatever its called?
I got a bit too greedy and got 265 (10.5inch :)) for the new rear tyres, and they have turned out to be too close for comfort. I need to get this sorted before the track day on Saturday.
Can anyone recommend where I can get this done? Anything to watch out for? Approx prices?
https://www.sau.com.au/forums/topic/2602-rolling/
Duncan, I have 265's on mine and they haven't been a problem...
I have the guards rolled on my Pulsar, it chipped a bit of the paint and also caused a lot of the strength to go around the panels (they bent easily).
Yeah, approx $40 a corner.
https://www.sau.com.au/forums/topic/2602-rolling/#findComment-47165
Thanks for the feedback, all. I ended up getting them rolled at Tempe tyres for $60 (rears only). They seemed to do a good job, no cracks in the paint etc.
And the tyres are no longer rubbing - I'm not sure how you guys fit 265s/275s without rolling them, is there some sort of tardis under your guards?
https://www.sau.com.au/forums/topic/2602-rolling/#findComment-48314
Bah dont listen to christian!
It comes down to the exact right offset of the wheel.
If you get the right offset you can fit 265 tyres on the rears no probs and thats what his wheels are.
I know a guy who can fit 275 to his nissan 180sx.
https://www.sau.com.au/forums/topic/2602-rolling/#findComment-58700
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
