Hey guys im lookin at buy a rb26dett from japan!
Could anyelse help me if this is a n1 motor or just a gtr 32 motor.
any help will be great
all i know is this
Hi Trent,
Sorry, I have no idea of other numbers stamped into the block. The
head is stamped 141 at the back pass side below the cam cover.
The engine is not modified past the original Omori specification.
The engine is from an Omori factory R32 build. It was stolen and recovered. Then my company bought it, and it was dismantled, as could not be re-registered.
Sale includes the harness and ecu. Nismo clutch and transmission are
additional.
Photos attached
https://www.sau.com.au/forums/topic/260234-rb26-help/
you would need the numbers to confirm if its a nismo motor. normally there would be a nismo plate on the motor. plus the block should be a 024U00. if they cant provide the numbers then tell them they cant prove it and youll only pay for a normal RB26 instead of a nismo motor. that way if it actually is a nismo motor, bargain. if not well you didnt get ripped off.
https://www.sau.com.au/forums/topic/260234-rb26-help/#findComment-4466372
Check this out..
http://www.skylinesaustralia.com/forums/Rb...o+engine+number
The number on the block that has .........X and then a R above is definatly a R34 Nur engine, these engine's are build by Nissan Motorsport and have the following specs in stead of the STD Rb26:
- R34 NUR cams little different then STD R34
- N1 block (24U)
- N1 piston rings
- piston + conrods weight balanced
- crankshaft weight balanced
- Nismo F112 bearings main + conrod
- N1 oil pump
- N1 waterpump
As you state all the bolts, nuts, the complete bare engine is new from Nissan Motorsport.
Here are some pics of a few I have/had:
https://www.sau.com.au/forums/topic/260234-rb26-help/#findComment-4466427
its only 4600 to my door.
apprantly it has 25 000kms
as i have a pic off the dash
hmm just thinking if i have to pay any tax for getting it.
No way its a N1 motor for that price dude to be dreadfully honest.
Im happy to be proven wrong, but it could be a very tried motor, you just dont know
https://www.sau.com.au/forums/topic/260234-rb26-help/#findComment-4466720
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
