As you might know , my rb26 has spun a bearing.
i have replacement parts to fix it but my only problem is getting the engine out of the car and doing it myself.
seeing as im really low on cash i was wondering if anyone could lend a helping hand to help me rebuild the motor.
ill happily pay you for your services etc but my main priority is getting my car back on the road as i dont have a daily.
any help will be greatly appreciated !
https://www.sau.com.au/forums/topic/260299-rb26-engine-removal/
pity u so far away,otherwise be more than willig 2 lend a hand. :D
still need the engine crane? what sort of help do you need?
yeah mate ill need the engine crane closer to the weekend as i think ive got a mate to help me out.
need to pull the engine out and replace bearings and oil pump , possibly will be replacing crank , rods & pistons .
Don't forget you will need to get the assembly balanced as well. I'd also just the bore a light hone.
FOOLBOOST & Myself are pulling the engine out and pulling it apart and getting everything that is going in the motor put in professionally :)
Depending on the severity of the mechanical dis-symphony - you'll have bearing material through your turbo bearings too. Make sure you fully clean out your oil coolers etc of any bearing material - it gets everywhere, trust me been there got the t-shirt.
Listen to Andrew, take his word as gospel. He knows his shit.
P.S. Cheers again Andrew for all your help :(
yes i know this
just my car is a pain in the arse and is a big regret to me :D
want it fixed so i can enjoy it again :)
Turbo's will be fine providing you didn't drive it too much once she started knocking.
You will have to replace the oil pump though.
Cheap RB30E bottom end, shove a washer from the rb26 oil pump in to the rb30's std pump to bump up the pressure a little, block the rear oil restricter, 2 low tensioners suitable cam belt, cheap headgasket and it will be fine while you spend some time getting the rb26 built back up. :)
+ you'll get to experience a little rb30 wrath. :(
FOOOOLBOOST has done rb30 stuff before so he will probably make the same recommendation. :cheers:
Edited by TheRogue
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
