Basically I'm ordering a new front bar for my 33 GTR, but I'm chasing the series 3 front bar and splitter (as the price difference isn't all that much).
What I need to order it though is a chassis and model number.
Can anyone with a Series 3 (97+) 33 GTR help me out and post up your Chassis Number and Model number off your silver plate on your firewall?
For example, mine is:
Chassis - BCNR33-000921
Model - GGJPRQFR33ZDAGJ---
Cheers :P
https://www.sau.com.au/forums/topic/260665-anyone-with-a-series-3-r33-gtr/
Hope this helps mate
Chassis Number
BCNR33-041315
Model Number
GGJPRWFR33ZDAAAP-C
Cheers
Perfect. Thank you :P
Projector headlights are on the "to do" list, but at 2.4k, they won't be done anytime soon.
Just a quick question as it is kinda relevant, is it possible to do the projector headlights to the series 2 r33 gts-t?
I know i could always get a set of the series 3 headlights (but that's friking expensive).
Is there any other way it can be done?
  • 2 years later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
