Hey i have searched the forum and i couldnt find an answer to my question, on an R33 the air con diagnostics has a mode that is suposed to display 3 different temperatures from different sensors but when i done it on mine it only displays 2 instead, ive seen a few people who posted that they get the same thing but no one has said why, is it suposed to be only 2 or is it 3. Has anyone else here checked theres ?
Its very simple to do, could i ask that a few people with R33's please check theres and tell me if they get 2 or 3.
I'll write down how to do it to save people from searching the forum to find out how to do it.
Well within 10 seconds from turning the ignition on press and hold the off button on the air con until the unit goes into the diagnostics mode, u will know when its there cos the display lights up fully, now the mode we want is mode 5 (Sensor Recognition Check), to get it to this press the red arrow 4 times, there should be a 5 displayed on the screen, now you press the demist button in the aircon to cycle through the sensors, when it goes back to the 5 it means that its finished, so i think i have explained it right, so yeah please someone help me work out if i have a problem or is it normal, and if it isnt any ideas how to fix it ...
Thanx people ..
https://www.sau.com.au/forums/topic/260731-air-con-sensor-recognition-check/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
