i've got a 32 gts-t with quite a few km's on it and a big turbo back exhaust and i'm looking for a few extra Nm & kw...
I'm thinking a turbo rebuild and 10psi
a pod with cold air pipe
tuning to sort it out
any ideas of any probs i may encounter with the std computer
any other mods that may be low cost (i've notice 'cooler kits are a bit pricey)
any recommended tuners in the sydney area
is a bleed valve the easy option to increase the boost
https://www.sau.com.au/forums/topic/26074-daily-r32-performance/
1) a high flow panel filter in the stock airbox with a pipe running from the bumper feeding cold air
2) bleed valve to 11-12psi
3) SAFC tuned on a dyno to get the best a/f ratios
assuming your engine and turbo are in OK condition this shoud yield some more power to play with... and should cost less than $500 all up...
Waz.
sounds pretty good. ta for the tip...
what exactly is a SAFC? a brand of piggyback computer? forgive my ignorance
going to rebuild the turbo to be safe as i don't believe it will put up with much more boost. what boost do the ceramic wheels normally put up with?
Hi cul202, I agree with mase, get a RB25DET turbo. swap the wastegate actuator from your RB20DET turbo. RB25DET is 0.4 bar whereas RB20SET is 0.6 bar. The RB25DET turbo flows more air at the same boost level, so gives around 20 rwkw more power. It bolts straightup, so cost is minimised.
Also makes a better base for a ball bearing hi flow later on if you decide you need more.
Hope that helps
That's spot on what i did sydneykid, thanks for the tip off on the wastegate in the other thread. Lots of fun. If you want a car for straight performance then the vg30 would be good but it's a tad lagier. Rb25 turbs is good if u like a bit of drifting and a more smoother power curve.
another option is to get your standard computer re-chipped for like $200.
for about $1000 you could get about 170rwkw.
Panel filter for standard air box. - $100
rb25 turbo - $500
bleed valve - $60
rechip computer - $200
gtr fuel pump - $200
that should be about $1000 and give you a reliable 170rwkw from your RB20.
After that, the next thing should be an intercooler. It's almost summer and the stocky one is a little small for that sort of power.
A GTR intercooler is now worth about $600. piping say another $400..
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
