Hey team,
I have...
1. x 2" 3 pt sabelt harness with shoulder pads - have only used for 3 meets. easy to install
great condition - $120.00 SOLD
1 x standard side mount intercooler and piping for series 1 r33 gtst
conditon - dirty, but good for its age
great for clearing defects!
$40.00
1 x standard cat back - good condition
$40.00 SOLD
1 x front/dump pipe - $30.00
1 x blown high flow turbo
can be rebuilt, but unsure
$100.00
1 x set of orange indicators for r33 gtst
good condition
$20.00
Im located in Sydney - Lane Cove/ Hornsby
email - chrisquick1982 at hotmail dot com
Cheers,
Chris
****** New stuff which I found!!*******
stock R33 sway bars front and rear
$40.00
2 x R32 gtst rims
2 x S15 rims
All 4 have f**ked tyres on them, these would make good,spare drift rims or for motorkhana's - you just need to get the rubber off, and put other tyres on :)
$50.00 for the 4.
1 x standard R33 GTSt radiator
$40.00
1 x standard r33 gtst airflow meter
$30.00
Bobby!
I used the back seat passenger seat belt mounts for ym r33 - some cars have holes in the rear parcel shelf, Ando's does in the s13. I know people have made a fitting for them in the parcel shelf too!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
