well, the stag is stalling. i'm presuming that its an AT issue primarily because when the car is warm (seems to run completely fine on cold start and idle in neutral is fine and steady), i start to get issues when slowing to a stop - engine revs drop RIGHT down, as though trans isn't dropping down gears? once these games have begun it stalls intermitently during accellerating when it need to shift up as well. engine revs drop right off to nothing, though it will intermittently pick up again as though the trans catches like when you jump start a manual. it's been doing this for a couple of weeks now because i've not had the cash to get it sorted. went to have it looked at the other day and was told it was the fuel filter being block up which while understandable why they thought that, doesn't ring right with me.
so i've got a couple of questions:
1. does my diagnosis seem reasonable? if you need more info before you can say yay or nay, let me know.
2. does anyone know of a reputable auto trans servicing centre they can recommend in perth?
or does anyone have a consult cable and software than can read the fault codes for me?
cheers,
Dave.
https://www.sau.com.au/forums/topic/260818-stalling-stag/
yeah mine did that when i put the breaks on also, would just about stall.
i had a transmission gasket leak. loss i pressure i put it down to.
now im up for a rebuild LOL ! take it to any trans workshop who can hook it up to there comp, or nissan dealer best bet. dont leave it too long. left mine for about 12,000km's and got the worst result hehe :P
all the best dude
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474035
do you still have your standard BOV in place? have you blocked it or removed/replaced it?
yep she's still a complete stocker apart from the almost mandatory stereo upgrade. why's that?
"yeah mine did that when i put the breaks on also, would just about stall.
now im up for a rebuild LOL ! take it to any trans workshop who can hook it up to there comp, or nissan dealer best bet. dont leave it too long. left mine for about 12,000km's and got the worst result hehe :)
all the best dude"
yowsers - i'll be a little pissed if i'm up for a rebuilt only 8months after buying it :/
any idea of ball parks prices i'd be looking at for an AT service?
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474122
hmm my M35's been doing that lately. i've been questioning the transmission ever since i bought it...
Had the trans serviced only 2-3 months ago though...so hopefully its not the trans for me...i think mine's more related to steering somehow...but anyway.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474158
If you don't know how long it's been since it has had a replacement fuel filter, I would at least just do it for the sake of it. They are inexpensive and as far as i am aware, look pretty straight forward to do as it is nice and accessible in the engine bay.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474230
had this done the other day, no difference - stalled about 200m up the road from the service place. initially i thought it was related to my p/steering as well, however had steering pump fixed at the same time, still stalling. have done some additional searching and people have been having the same prob tracked back to various sensors such as engine temp and air flow meter. will have a look in fast tonight when i get home to see about replacing them
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474246
not sure if it will fix your problem but reset the ecu by disconnecting the battery, pressing the brake pedal a couple of times and leaving the car for half hour or so. then come back and connect it up again and let the ecu start fresh :/
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474414
ball park figure for a service ... $150 . . .
i only owned mine for about 8months i think. previous owner had it for 11months (finacial problems, nice guy)
i just got the ticking time bomb, car's done 107,000kms now, got it at 84,000 if those numbers match up, get the service kit done, that ways its open for a reason, get them to do some ECU testing, in one hit
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474450
cheers mate, will try get it done next week sometime - going to be riding for a little bit i think :/
" not sure if it will fix your problem but reset the ecu by disconnecting the battery, pressing the brake pedal a couple of times and leaving the car for half hour or so. then come back and connect it up again and let the ecu start fresh :) "
cheers mike, will try both the ecu and AT comp in the drivers side kick panel as well when i get home tonight.
Dave.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474471
OFF TOPIC
oh yeah and something i found out also, (just a little easier for people to read)
click the QUOTE tab on the post you wish to quote,
if you wanna quote a few, the tab will go red, then you can click on the next quote and so forth....
then when done click ADD REPLY and thats were they'll all be :/ took me some time to work it also
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474512
If it were just under braking i would have thought your brake booster has a vacuum leak but if its playing up shifiting upwards through gears you could be in dramas. A service never hurts - its something that should be done routinely anyway so may as well do it and if it fixes your problem then sweet.
Definitely sounds like a leak tho. Did you try the ECU flash...?
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4474564
cheers,
Dave.
Sounds reasonable buddy...loss of fuel would deffinatly do this, and seams its not an expensive thing to replace a fuel filter try it first. If it doesn't work at least you've got a clean fuel filter in.
But on the other hand does the M35 run a accelerator cable or is it electronicaly controlled?
My mates BA ute(ford) is having similar probs at the moment. The mechanic thought it was the throtle possision sensor/swithch. Just another idea.
Edited by mattye
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4475060
Hope i'm not confusing things by what I posted. I think the original post was about a series 1 stag. Mine is an M35 and I'm not 100% sure but I dont think it has a fuel filter. It does have drive-by-wire though. The s1 stag has a fuel filter but not electronic throttle.
mine's due for a service sometime so will just get it looked at then.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4477751
I solved my M35 stalling problem by having the TPS (throttle position switch) reset. I am not sure if this will help you but it did stop the stalling. It does now idle about 100rpm higher than I would like but it is better than stalling every I pulled up quickly. It now idles around 800 - 850 rpm in neutral and it is meant to be 750 rpm.
To reset the TPS it is just a sequence of turning the ignition on and off with minimum time for each part.
1) turn ignition on for at least 2 second.
2) turn ignition off for at least 10 seconds.
3) turn ignition on for at least 2 seconds.
4) turn ignotion off for at least 10 seconds.
this is meant to reset the TPS.
I think the stalling may be slightly to do with the TPS but I suspect it is also to do with either the O2 sensor or the spark plugs. This is not a definate answer but it is my gut feeling.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4477787
Cheers
Andy
Awesome!! Hopefully this works for me. I didn't realise there was such a way to do this...
Mine idles on 500rpm (no kidding) sometimes less but the needle wont show much below 500rpm - and about 600-700rpm with a/c on. I know it should be higher than this and it doesn't just affect idle, it feels a bit dead sometimes when just cruising along - like it just drops out until i touch the accelerator again.
The other thing it affects is that it rolls backwards if i'm on an upward incline and i lift my foot off the accelerator. normally auto's shouldn't do this but ours does and its a bit disconcerting :S
Hopefully this is a simple fix otherwise I've thought maybe I need to get the idle adjusted (can you do that?).
Its really only started stalling lately - and only with a/c off (a/c lifts the revs a bit you see) so I'm pretty certain its just something simple like the above. Will let you know what happens...
Other suspicions i have are air-flow meter or spark plugs (no idea what they used in compliance).
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478078
There is no way to adjust the idle speed. It is all done from the TPS and the computer.
Try and look for the G35 service manual on line. Lots of useful information that relates to our cars.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478313
Cheers
Andy
I've tried resetting the TPS like you said, and I've also cleaned the AFM and reset the ECU (disconnected battery), but its still doing the same thing. Drives fine out on the road but when idling it seems to drop really low then quickly steady itself at 500rpm, where it doesn't feel smooth since its idling too low. It does make the steering harder too when its revving this low.
Will check the manual but its looking like a faulty TPS or something like that. Any way to check ECU fault codes by myself? or do I need to take it to Nissan (or someone with a consult cable & software) to do that?
I knew a lot more about my old stagea (series 2) but with this one I'm having to start over...learning it all again.
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478429
You mentioned that you were not sure what they did with plugs at compliance. The standard plugs for these cars are Platinum or something similar and are good for 80-100k km.
I have been reading about the Blatz, IBDII software and cable and from what I have read, although there is a lot more to read, it should help with the fault codes and allow you to reset them. At about $200 bucks it sounds like a good investment.
http://www.blazt.biz/index.php
I have also listed below the info from the manual. Some of this may help.
Accelerator Pedal Released Position Learning ABS0003L
DESCRIPTION
“Accelerator Pedal Released Position Learning” is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning ABS0003M
DESCRIPTION
“Throttle Valve Closed Position Learning” is an operation to learn the fully closed position of the throttle valve
by monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch “ON”.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Cheers
Andy
https://www.sau.com.au/forums/topic/260818-stalling-stag/#findComment-4478534
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
