hello all, had my car dyno'd and tuned last week, have bosch 044 fuel pump still with standard fuel pressure reg, and was told the the fuel pressure at idle is to high, hence making the car idle really rich and at around 1100rpm. Was told the the standard fuel pressure reg cannot physically bypass enough fuel back to the tank and could be putting excess load on the fuel pump at idle.
I am running,
Safc, bosch 44 fuel pump, 11psi boost, front mount.
Was interested if anyone else running similar setups to this has an aftermarket fuel pressure reg, if so what brand? did u install it yourself and if anyone has any idea wat the correct fuel pressure should b in the fuel rail at idle?
Any help/feedback would be greatly appresiated
https://www.sau.com.au/forums/topic/260972-fuel-pressure-regulators/
think 40ish is standard. i got a nismo running at 42 psi. have a walbro fuel pump. no idle issues. got my tuner to set it up when the hi flow when on as still running standard injectors, gives me a little bit of head room.
Edited by Pal
i've got the standard 25 fpr, had the car tuned with a bosch 910 (~400hp pump) then swapped to an 044 and it didnt change the idle at all. fuel reg ended up dying and replaced it with another stocker and its still fine
370rwkw, Bosch 040 external pump - factory fuel reg
Sounds like if anything your fuel reg might be stuffed, or the return line somehow blocked,
You do not need an aftermarket reg, you have a problem elsewhere.
hey again, am lucky enough 2 have a house mate with an r33 gtst wid similar mods. His car idle's perfectly so i swapped my fuel press reg with his and still the same thing. Since then my car has started 2 stall randomly. Someone suggested my air flow meter is stuffed, but that has been swapped as well still with no difference. Has anyone had issuses similar 2 this? Please help!
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
