hey everyone, was just wondering what you guys think of painting stock R33 rims to a Black,.. ive got a two tone skyline silver on top grey on the bottom so would be good to know what you guys think cause im still ummin and arring because dont have the money for proper rims yet lol.
https://www.sau.com.au/forums/topic/261089-painting-stock-rims/
I would say definitely paint the stock rims with the $3 paint cans from bunnings if want.
Don't pay big $$$ to get it powder coated. Then u might aswell get bigger better rims.
If u are concerned about ur car looking good with painted stockies.
If the car is neat, has a good paint job and has a kit, the painted stock wheels will look awesome.
But if ur car is too stock, and a lil piggy, painting the wheels will make it look boonga.
The R34'spull of the painted rim look cos they are modern. If ur car is a R32 then painted stockies will look like 14" hub caps spec steel wheels with very high profile tyres. YUCK
My 2c
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
