Looking for an exhaust shop in north shore area for some custom exhaust work. Good workmanship, friendly, reliable and cheap :). You know the kind of shop you'd trust to take your own car to.
Appreciate any help.
Edited by BaysideBlue
Looking for an exhaust shop in north shore area for some custom exhaust work. Good workmanship, friendly, reliable and cheap :blink: . You know the kind of shop you'd trust to take your own car to.
is anything EVER cheap in the north shore?!
Brookvale Muffler & Mechanical Centre
24 Roger St
Brookvale 2100
Ph: 9905 4379
They do good workmanship, are friendly, very reasonably priced, but can be a little unreliable (but who isn't). Nothing to much to worry about just a little unreliable with the time the work takes and pick up dates etc.
I had them do a custom mild steel 3" turbo back exhaust with mandrel bends and good workmanship, and a pod filter with aluminium heat seal / box.
The exhaust cost $955, but I supplied my own dump pipe and cat.
  • 4 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
