Hi all,
Just wondering if the RB26 rocker covers, valley cover and cam cover will fit an RB25 head??
im pretty sure its not a direct change over....., cause a few things wont line up & the plenum chamber might affect it.
anythings possible if you got the time and money.......you'd have to customise one of few things to suit.
if you look into the search....i think many people have attempted this
Yeah I had a quick browse through search function and I couldn't find anything. .
Plenum is front facing so shouldnt be a problem. . Not sure about the other things??
the brackets i imagine are different...so hence.....the rocker cover etc needs to be modified....
im pretty sure the inlet pipe that runs along the top of the RB25DET will be an issue....
as the RB26DETT does not have the plenum chamber set + inlet set out that way
so hence...modification is necessary.
thats funny....i just typed it in google...and HEAPS showed up.. as i said, this is something that many peopel have tried or want to do
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
