Yeh, If it says 98 over here in WA or over there in Qld, its the same. The fuel from BP or Vortex 98 or whatever from shell comes from the same company. Shell in Singapore IIRC . Just gets sold at different outlets.
I think you are missing something regarding the production sharing agreement between Australian refineries, mate. The bulk of fuel sold in WA is produced at the BP refinery at Kwinana - no matter what the badge on it. There may be some stuff bought off the spot market, and so produced in Singapore, but not that much. Unless Kwinana shut down when I wasn't looking!
And, yes, 98 octane is 98 octane. How the particular fuel makes 98 octane may differ, but the outcome is the same.
And there are many threads on which fuel is best and so on, which explain some things about the way the refineries share production.
Cheers. :banana:
Guest
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
