three words post
sheer brilliance - once again - mick for pm? :P
would if be worth it if i came down thursday night from sc :D
if hot 15 year olds with icecream is your thing then defs :D
get back to work nig! Uni is fail. that is all
totally - im in the 24hour computer lab doing a group assignment
fml
becareful mick his looking for a reason to go down on you mick!
dw i have plenty of time to cup aswell tasman
(deletes false aligations)
tris if i make president, ill make gay marriage constitutional. just 4 u :D
sounds delicious
because we believe in the love that exists between two vaginas,
the most important kind of love, is the love that exists between two naked women while i watch :P
Edited by astrotristan2
the most important kind of love, is the love that exists between two naked women while i watch :D
I saw two females make out at a club I was at on the weekend. Swear to god, I was all giggles.
haha i own your novice sight, tristan can confirm.
if only i had access to my on board camera. was at schoolies back in the day.
involved me / mates watchin and 2 drunk chix in there hotel room.
lets just say one squirts...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
