Brand new dual compound tyres goign on the bike = col happy in the pants... :rofl:
i got rid of that rash too josh, little bit of metho and some jim beam...
rub jim beam on your balls and the metho is to drink to help as the bourbon burns your shaved pubes...
morning bishes
anybody want to bring me some breakfast?
fridge is empty and too hung over to drive at the moment
this
ouch
Oh stupid me . . . I was doing it the other way round !
:rofl:
Does anyone know where to buy 3m branded Di-Noc carbon fibre vinyl in our area? Dont really wanna buy it from 3m directly....
morning bishes
not bringing you breakfast... but... speaking of driving. Did you fix your intercooler* bracket yet?
*Brandon: IN TA COOLAH. NOT Oil cooler. It does the green stuff, not the brown stuff.
Shotty not
fucking...
STOP RAPING ENGLISH!
The term SHOTGUN means that you wish to accompany the person doing said acticity. Saying "shotty not" means you're going to stand next to the person who's not doing it... it doesn't mean you're actually out of doing it yourself. The term SHOTTY NOT makes no sense at all, and it should be illegal to ever utter it (except for purposes of my explanation).
If you don't want to do something you simply say "Not me" OR "Dibs on not".
"Shotty Not" is just another prime example of Australia bending the english language over the counter and aiming for penentration.
now... don't make me slap you like a bitch ;)
P.S I think that dude in the photo is now one of my heros :rofl:
Edited by Isola
not yet. debating braving the sun and going outside, but still a bit seedy and dehydrated, so thinking of putting it off until tomorrow.
going to the coast shortly for a few more drinks, so not even sure if it will get done tomorrow.
FOUND SOME MOTHERFARKEN PRINGLES IN THE BACK OF THE CUPBOARD!!!!!!!!!
WEEE HAAAAA
i was starting to contemplate eating the cat (no eating pussy jokes please)
f**king...
Shotty not reading any more of your posts :cool:
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
