I could give you a reference. I've seen your hand work :domokun:
BAHAHAHAHAHAHAHAHAHA!
Job for John
Needless to say I was expecting something different.
Still as feminine however.
yeah, me agains...........
I'm well. How bout you guys?
I slept my whole day off :(
im pretty good 1 exam down 4 to go
I've got one module to finish by the end of the week. Fun stuff :domokun:
so today was another all day service, road test is tomorrow morning.... josh, what time do you want me to blast past your work with open pipes from the 430 Scuderia?
BTW jas
You wanta find skyline drivers in Toowoomba?
Go hang out in Ruthven street while they do burnouts all hours on the night on Thursdays while im trying to sleep...
Just too many "kids" in them these days wreaking the "image" of skyline owners in general...
Now I own fast cars & bikes that "tools" cant afford... :)
Edit: Now some older bloke in his 40's is saying on the forum he subscribes too "Too many kids (ie. me) driving these cars these days, time for me to by a S class Mercedes"
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
