I burnt my pipe last night, if that counts?
In other news,
I was gonna come out last thursday but you know, not driving a riceline and all I would feel left out. Plus, I don't have a hat.
Edited by hylian
Nice nice.
Burnt your fingers yet?
If you burn your fingers your doing it wrong
*twirls pipe*
im soo getting my hat on on thursday
Flat cap ?
Depends on what type :bunny:
Dont worry about not having a riceline.
Geez, i drive a maxima-wannabe. Its not a maxima but isola enjoys arguing that it is.
Get a hat though. And if you can a pipe.
Come out anyway. Jason and I are both big Ford fans. You can hang with us :bunny:
+1
As for type... a genwine old school corn pipe... only the best tobaccerrr for this ollle farmer
Morning Mangs
Keen for hat tipping, keen for pipe (that's what she said)
OMFG I JUST CLICKED THAT 'Kittens in tiny hats' LINK WITHOUT REALISING IT WAS YOUTUBE AND IT WORKED!!! WTFONEONEONEBARBEQUE
Need to start bringing headphones to work I think :D
your at your desk at work at 7:39am
By 7:15 normally. It's by choice though, I do it so my trips to and from work are half an hour not an hour.
sucks to be you
I was going to say no, because I get to go home at 3:15, but then I read this:
ill get to mine around 10, and be home by 3... :D
What do you do btw?
Blocked website at work hey?
Not at mine. I can watch as much p*rn as I like.
granted I work from home though :)
Pootube used to be blocked, but they upgraded the filters recently and it must have slipped through.
Massive fail though, I just clicked on a thread in wasteland and got a big "DENIED! ADULT MATERIAL PRON ETC YOU HAVE BEEN NAUGHTY!!!!" message and now it seems the whole of SAU has been blocked :(
Now I have to use this sh*t slow connection I have h4xed to bypass the filters.
The work from home option is sounding good, I now can't access SAU or my personal email without h4xing, plus I have sh*t small desk. I should be able to a fair bit of work from home soon. At the moment though, I don't have any work suitable for taking offsite :(
What is it that you do that you get to work from home?
account manager
work in wholesale with the major CE retailers and FMCG retailers...
basically been in sales now for 11 years...
Eat a bagel, like a boss... send some fax's, like a boss... etc etc
spose i better go iron a shirt and go to work...
need to stop by the bank and post office etc on the way... might take an hour...
also feel like a HJ's brekkie wrap for some strange reason today... ummmmm
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
