Just another f**king weekend in shithole. Good new is another 3days more days and I'll be home. And more low+major servicing over the coming weekend!
This month is gonna be f**ked too with so many bills coming. $1.5k water bill....
shocking weekend. had the flu for the duration of it. still got it, so staying at home and getting in some ps3 time
went down to mercury a bit for the dyno day though. entirely too many flat brimmed hats around for my liking....
WTF?
All the joy of home ownership man. Long story short, got 2 main water pipe burst while I'm away from home and clocked 800kL of water in 3weeks. Just to give an idea on consumption, we use around 40kL per quarter.
Morning guys, hope you had a fun weekend!
Was at a party saturday night... a mate decides to go home to get his ipad so gets driven by someone else. First mate decides to ride his trail bike back to the party and comes off it halfway back. Hadn't been drinking or anything.
Broken elbow, a wrist the size of a tennis ball, and severe internal bleeding in one of his legs. He can't walk on it at all, and can barely move his left arm. Poooor karrrnnnt. Took him pizza last night..... doesn't really help that much though hahahaha
Thats no good.
I kinda regretted not getting the project mu scr pro rotors along with the suspension now with aud going up...
Skid to leave
noted
sarp hottie?
rofl rofl
i drove past today on the way to work
huuuge huuuge skid to leave - goes for about 20metres, epic black lines
but yes, i can only imagine the crowd there..
Morning mangs, scarnon, etc.
Anything happening for origin this time?
How was everyone's weekend?
Skid to leave
Hey mangs. Weekend was alright. Not long enough.
I feel your pain. We've been having bucket showers since Thursday waiting for some f**ker to come out to fix our hot water!
At least you have a PS3. The lowly scum (like myself) don't have access to such fancy thangs.
That's rough man. How's he doing now?
oi question
if my shifter thread is too thin for my dildo shifter thread - where can i get an adapter?
ive heard ppl say u can use hellicoils (spelling could be wrong)...
thoughts children?
my current adapter thread shat itself - and a stock gear shifter is not as awesome as my dildo one :whistling:
yeh i have considered it - but atm would prefer a quick fix option
unfortunatly my racetape and zippy tie skillzz (that killz) cant be used in this scenario :whistling:
Skid to leave
I'm heading out to Swifts sports club to this.
http://www.xxxxgoldv8supercars.com.au/gold-retreat/
cut the end off the shifer and weld a bolt (with the head cut off) with the right thread onto it
thats a bit too cronic for me man
im just looking for those coil adapter thingss
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
