Find me a new sticker and I will. Has to be something cool though! It's only still there because I have nothing to replace it with.
name what you want and ill buy it :yes:
F*cking lol
just bought it.
thats f**king love right there flamin mongrel
<3
Lets all get naked?
You are one hit tipping worthy mang :)
+1
i'm a man of my word :)
What about that time you said you wouldn't get it in my eye?
sup
Scarnon mang
Ravbat! What's crackin?
Hahahaha I ninjad my post my last night... hit it and bailed as soon as it was posted cause I didn't think anyone else was online... your post was 1 minute after me! Hahaha!!
Riding a Horse - You're doing it wrong!
f**kING. LOL.
Think im gonna need a phoneworthy... I'm running out of time
The pig is roadworthy motherf**kers. Rego on Monday n then I get to drive again hoorah! Car is still getting too hot though. its on like 3/4 on the gauge. Radiator isn't blocked but I dunno. The electric fan isn't coming on when its getting too hot though. Ideas?
checked the thermo and water pump?
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
