speaking of sammich its time for lunch!
building mum a computer today out of spares, although i did buy her a new video card, its more powerful then my old one :woot:
anyone got a 120mm hole saw they can lend me? new PSU needs to vent out of the case
getting hungry too. ducked out from work early.
managed to get myself into a bit of a pickle with our friendly constabluary
will update as events unfold today
did they find a "cop" In your boot. ;)
a freshly butchered one :P
will just update everyone on thursday, this being a public forum and all
don't think it will trump isola's story tho. that was a crackup
I need to borrow r34 LH & RH mirrors for compliance.. PM me if you can help
How can you borrow mirrors ? ;)
More importantly if you guys want to have a look at some... a lot of skantly dressed women pull up a chair on racecourse rd around 430pm. There was so many heading up that way about a hour ago... :P
Evening all
Somebody may have a car in a workshop getting work done or car could be off the road for some reason.
There are endless possibilities but i will leave it there.
they have white faced ones as well with red dials, but thinking of sticking with black as it will match my standard cluster
def stick with black.
They look pretty sweet. I approve :)
+1
How can you borrow mirrors ? :worship:
More to the point... how do you then get your complied car roadworthy once you've given the mirrors back? and if you get it roadworthy THEN give the mirrors back... how do you not wind up getting defected to the Nth degree? Sounds like a foolhardy plan to me.
compliance is alot more strict then a roadworthy john, when a car comes into the country for compliance these days it's got to be pretty much 100% stock.
For a roadworthy you just got to have side mirrors of flat glass, nothing special. Guessing this 34 has aftermarket ones?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
