always
hairy muff
i like the ribs i just ate at the petrie tavern... $25 worth...
best ribs ive ever eaten in my life... had to thank the chef, was super impressed...
hairy muff
Should have come said hello
I refuse to go to the petrie tavern... it screams dodgy :P
local also hey?
i thought the same thing, but the food was amazing for a pub/tavern...
heaps better than warner, lawnton & albany creek tav's... their pricing is also very reasonable for what you get...
i will be going again...
If thats the kind of loves that get dished up in here... Count me in
face sex?
local also hey?
Yeah I'm about a 5 min walk from the tavern. You around this area also?
I might have to actually check it out based on your recommendation
We're all relatively local (those of us that count)... Tavern night?
You home tonight, Mang? Lyss is going to Zumba at 7, so I could come up and fix it if you want.
Sorry mang, I didn't see this until too late.
I have no magnetiz'd that screw you dropped though, and vacuumed all the crap. I should be home the rest of today and also tomorrow morning.
Or you can just do it whenever.
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :P
Or you can just give me the bits and I'll put it back together. I've had a look and you haven't done much damage at all, I forgot how easy it is to do coil packs when there is no valley cover on :laugh:
Busy this weekend, that's why I was asking about last night. I can come over after tafe one day if you want? Or I'll just give you the bits on Thursday. It's not much damage at all. 8 screws, one bolt and 6 clips I think was all that need to be done up again.
Yeah im in Warner...
The warner tavern is too upmarket now (in terms of pricing) their food is ok, but not worth what they charge...
So we've been going to PRMBC & the lawnton tavern lately... But found a shopper docket for buy 1 meal get one free @ petrie tav and thought "hey why not give it a go"...
So two main meals, an entree each & 4 or 5 drinks later $42... Happy days...
Then the ribs of my life... It was a very good night...
Yeah id be up for it... small crowd would work, not much dinning space in there...
The ribs are all ive thought about since Friday...
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
