Brakes changed, lunch eaten, spoiler removed, trip to clark rubber and autobarn (where I was told about an apparent defect blitz this weekend lolzzz) and now to reinstall third brake light in rear window somehow... wooooop
So what? You and Jason used to move it about 20 pages overnight and say nothing.
Great days, great days. Sigh
Who's up for top gear live?
http://www.topgearlive.com.au/brisbane
I'm thinking Platinum tickets ($130)
I'm going on the sunday. :cool: It was the only day that had paddock passes left :yes:
Oh
Hey Geoff!
When did you get a duck tail spoiler? You didn't tell me about this!
How the hell have you been mang? Long time no see.
Secret :)
Not bad yourself? Has been a while
stein glasses are an evil invention, they force you to drink more.
Ftt, you were home by 8:20 am:
alright off to mexico this arvo!
Clearly they didn't hit you too hard
I'm going on the sunday. :thumbsup: It was the only day that had paddock passes left :)
F*CK! No paddock passes left all all now
damn all my unorganised and non-committal friends...
f**k, pulled my lower back while doing some wiring in the car this afternoon... just twisted at the hips to my left and SNAP... couldn't get out of the car, couldn't move from the position I was in.... luckily a friend was over so they helped me get upstairs.... now lying in bed playing COD, but I think I'm gonna need beer too
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
