glad i was working up the coast today
bruce highway is a carpark heading north after another accident at boundry road...
thats three this week.... time to build another over pass to over pass the over pass for the accidents... :thumbsup:
Yer i left work at 4pm on the dot today, decided to go the back way through old northern road and over youngs crossing, was a very slow crawl, i love auto's though, glad my car was on the driveway at home.
Just on a side note, martin how hot did carly look tonight? was a good drive into the city.
http://honda-tech.com/showthread.php?t=2763036
Not sure if most of you have seen this, as its an older thread, but impressed me none the less
Civic bodied Subaru WRX.
I gave her three thumbs up
Awesome!
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
