thanks guys, i just hate funerals... and the wife is ok, it was their time...
wish i didnt have to go to the funeral, would rather be working on a hot engine in a tin shed in the middle of summer...
this
What are you using at the moment Jeremy?
You just had a highflow installed, didn't you?
Still stock everything ATM, but I have plans for hi-flow R34 turbo and nistune...... plus this, plus that, then that and then another that.
Keen. Got harness and everything needed for it? How much you want for it?
EMU.
http://i21.photobuck...ur/IMAG0038.jpg
Universal Harness.
http://i21.photobuck...ur/IMAG0039.jpg
Comes with CD and Shizzle.
http://i21.photobuck...ur/IMAG0040.jpg
$500.00
commiserations Col ad Missus Col
EMU.
Universal Harness.
$500.00
You can keep your spark plugs :P
So you just wire that harness into the car's loom then off to the tuner? Is there wiring info on the cd?
I shall consult with my official mechanic when he gets back from the sticks and let you know.
Col, not good mate. Just make sure you look after yourself and your wife.
McFly, what ECU are you running? A Chipped 33 unit? The SAFC might not allow you to do much besides trimming some of the fueling points. They work great on stock management if you want to up the boost a little on a 'stock' setup.
McFly and Jez, Nistune is the best option in my opinion as it keeps things looking stock and gives you the same *or similar* level of tunability to that of a PFC. Being that you both have 33 setups (McFly I'm assuming you're running S1 33 ECU and loom - or is it a fiddles 31 setup?), The Nistune requires a little jiggery-pokery to work. You will need a Type 2 Nistune Board and a 32DET Ecu or a Z32 DET/DETT board that requires some internal modifications. The mods alter the firing order of the injectors and trigger for the coilpacks.
Type 2 boards with Nistune software go for $420 + GST, then you'll need to find yourself a 32 ECU which I'd allow for $100. Misso might have his laying around somewhere, so bug him. I can solder the board into it for you no worries. The software is nice to use giving you easy options for upgrades. Select the type of airflow meter you have installed and what injector size and it will trim the maps to give you a good base to start from - in a tuning sense.
As for turbos, the more understated it is for a daily street car the better. That 3076R is a nice turbo. A mate of mine had it one with a machined out T28 .63 rear housing on his twin cam 2ltr MX6. The thing laid down 425hp atw. Problem with his was that it was internally gated. Boost control became an issue. That turbo requires it to be externally gated and I think with the housing size will be a let down if you want to keep the same sort of response you have currently.
A complete bolt on kit like a GT-RS or a high flow will be the better option IMO for a street car. I would lean towards the highflow as it can be passed off as`stock and means you don't need to fiddle pipework, etc to fit.
*end book*
Yeah chipped S1 33 ECU
Yeah mine is essentially a 33 S1 engine loom, just minor fiddling to get it to mate up to the 31 main loom. Nothing that would affect the ECU.
I could find an R32 ecu (looks at ute)... but doesn't that lose the VCT or something?
Hmmmm......
So in short what you are saying is: it will be a bit laggy?
I would rather have better response than a few moar killa wasps, so I might stick with the high flow option.
*end book*
A properly good tome, that was.
Edited by Smity42
If you want to keep the VCT you have to go with the z32 ecu.
Just called 'bribane turbo and tuning' or something like that, over at the gabba
To rebuild stock rb25 turbo, assuming parts are available, around $700
To steel-wheel: extra $350ish
To rebuild, high flow & steel wheel: around $2000
Poooooooop.
Poooooooop.
Dang....
Poooooooop.
I didn't think they rebuilt turbos themselves. Pretty sure they source it out. GCG has a great reputation and pretty sure they do their highflows for less.
Hypergear appear to be gaining popularity with their cheap highflows, but I am not sure what their reliability is like.
True... funnily enough I just came across your ad on boost from November, selling an Rb25 turbo. You still got it? I might be keen, to send off to hypergear/GCG to high flow it...
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
