thanks guys, i just hate funerals... and the wife is ok, it was their time...
wish i didnt have to go to the funeral, would rather be working on a hot engine in a tin shed in the middle of summer...
this
What are you using at the moment Jeremy?
You just had a highflow installed, didn't you?
Still stock everything ATM, but I have plans for hi-flow R34 turbo and nistune...... plus this, plus that, then that and then another that.
Keen. Got harness and everything needed for it? How much you want for it?
EMU.
http://i21.photobuck...ur/IMAG0038.jpg
Universal Harness.
http://i21.photobuck...ur/IMAG0039.jpg
Comes with CD and Shizzle.
http://i21.photobuck...ur/IMAG0040.jpg
$500.00
commiserations Col ad Missus Col
EMU.
Universal Harness.
$500.00
You can keep your spark plugs :P
So you just wire that harness into the car's loom then off to the tuner? Is there wiring info on the cd?
I shall consult with my official mechanic when he gets back from the sticks and let you know.
Col, not good mate. Just make sure you look after yourself and your wife.
McFly, what ECU are you running? A Chipped 33 unit? The SAFC might not allow you to do much besides trimming some of the fueling points. They work great on stock management if you want to up the boost a little on a 'stock' setup.
McFly and Jez, Nistune is the best option in my opinion as it keeps things looking stock and gives you the same *or similar* level of tunability to that of a PFC. Being that you both have 33 setups (McFly I'm assuming you're running S1 33 ECU and loom - or is it a fiddles 31 setup?), The Nistune requires a little jiggery-pokery to work. You will need a Type 2 Nistune Board and a 32DET Ecu or a Z32 DET/DETT board that requires some internal modifications. The mods alter the firing order of the injectors and trigger for the coilpacks.
Type 2 boards with Nistune software go for $420 + GST, then you'll need to find yourself a 32 ECU which I'd allow for $100. Misso might have his laying around somewhere, so bug him. I can solder the board into it for you no worries. The software is nice to use giving you easy options for upgrades. Select the type of airflow meter you have installed and what injector size and it will trim the maps to give you a good base to start from - in a tuning sense.
As for turbos, the more understated it is for a daily street car the better. That 3076R is a nice turbo. A mate of mine had it one with a machined out T28 .63 rear housing on his twin cam 2ltr MX6. The thing laid down 425hp atw. Problem with his was that it was internally gated. Boost control became an issue. That turbo requires it to be externally gated and I think with the housing size will be a let down if you want to keep the same sort of response you have currently.
A complete bolt on kit like a GT-RS or a high flow will be the better option IMO for a street car. I would lean towards the highflow as it can be passed off as`stock and means you don't need to fiddle pipework, etc to fit.
*end book*
Yeah chipped S1 33 ECU
Yeah mine is essentially a 33 S1 engine loom, just minor fiddling to get it to mate up to the 31 main loom. Nothing that would affect the ECU.
I could find an R32 ecu (looks at ute)... but doesn't that lose the VCT or something?
Hmmmm......
So in short what you are saying is: it will be a bit laggy?
I would rather have better response than a few moar killa wasps, so I might stick with the high flow option.
*end book*
A properly good tome, that was.
Edited by Smity42
If you want to keep the VCT you have to go with the z32 ecu.
Just called 'bribane turbo and tuning' or something like that, over at the gabba
To rebuild stock rb25 turbo, assuming parts are available, around $700
To steel-wheel: extra $350ish
To rebuild, high flow & steel wheel: around $2000
Poooooooop.
Poooooooop.
Dang....
Poooooooop.
I didn't think they rebuilt turbos themselves. Pretty sure they source it out. GCG has a great reputation and pretty sure they do their highflows for less.
Hypergear appear to be gaining popularity with their cheap highflows, but I am not sure what their reliability is like.
True... funnily enough I just came across your ad on boost from November, selling an Rb25 turbo. You still got it? I might be keen, to send off to hypergear/GCG to high flow it...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
