Everyone here is going apeshit. Moving cars to higher ground, running around screaming, sand bagging. I think i even saw a dude with a "the end is nigh" sign at one point. So much chaos. So much lulz.
Col, your area does go under pretty hardcore. I suggest you move the R if you can.
Edited by Isola
Waiting on the signal from the site manager to abandon ship. I have a feeling we're going to go down with it rather than evacuate though >_<
my back yard is flooded the pool is over flowing, my gutters are over flowing, the drains are back feeding water...
same, same, same, same.
im staying home...
not same :(.
Working next to the river. King tide today aswell apparently shit is going to get real.
Will be worse for you tomorrow.
LOL, I love it.
+1
A captain should always go down with his shit :thumbsup:
Urgh, flood warning now for pine rivers and strathpine. Couldn't move the 31 if I wanted to...
Should I go and sandbag?
Martin build me a computer. Kgo.
Yeah yeah, will get on it... Budget?
Ship even.
Go sandbag imo. $1500 budget.
Yeah I think I might. $1500 for just box, or box + monitors, etc? What does it need to include?
Yeah so like, I can't get home anyway, all the roads are flooded. Will have to wait it out
Box + Monitors. 2 x monitors. Quick enough for Autocad and a few pdfs/word/excel files open at the same time.
OK, will get on it.
SAAAAAAAAAAAAVVVVVVVE MEEEEEEEEEEEEEEEEE
Thats what she said.
Where you at? What u need? If you're at work I'm not far away :)
so the river has broken, time this shit just got very serious...
we are ok, the drive way is directing waters down towards the garages and the drains are over flowing...
lucky the concrete's sloped down the side of the house so its just taking all my gardens down to the back shed...
the lakes would need to rise about 4m for me to be in any danger of flooding...
if that happened 10,000+ around strathpine & aspley would be in greater danger...
im pretty confident we are safe... fingers crossed...
Err, they evacuated most of low lying stranthpine, and the bridge there has been cut. that being said i don't know your situation. But Still, hindsight and water damage can be a bitch.
Meh, house should be OK, it's up pretty high in Petrie. I just need to figure out a way to get to it, which means getting across the pine river somehow...
im staying home...
same here, but without the whole pool thing
Shit just got real....
Much lulz for living in low laying areas close to the river.
but different, different, different, different.
Samford is under water also. No ins, nor outs.
Where is Obe-Wan when you need him....
Agreed.
Good to hear you not going to be breathing water whilst you sleep.
Low level brisge is out, upper brindge is split-laned.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
