yer those camera's stand out pretty easy.
The song "theres a hole in my bucket" come to mind when i have pulled my car apart. Got the drivers side cleaned up and ready for metal to be cut out and new stuff welded in, passengers side is worse. This will take all week
is it an expensive exercise ?
Hahaha no thanks
Anyone have ideas for how to make a pressure tester for my piping?
I'm thinking PVC end cap, drill small hole in side, insert bike tyre air screw part, seal around the edges and hook up to compressor.
Replace AFM with this item and listen for leaks in piping??
Will PVC withstand 10psi?
It will work, i have one that I run off my compressor. Just be careful not to over boost it though.
Less likely with a pushbike pump thaan a compressor but meh!
  • Nope 1
Please note that A J Wyllie Bridge on Gympie Road, Petrie is currently closed to traffic in both directions. An alternative route is available via Youngs Crossing Road, Petrie.
Advice has been received from Main Roads that the lower bridge may be opened late this afternoon. This will carry one lane of traffic in each direction. They have also provided advice that the high (southbound) bridge will be closed for some weeks due to extensive damage.
Weeks! FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU
Time to find an alternative route to work...
Hahahahaha sweet... Yeah haven't decided if I'll use compressor or bike pump yet.
How did you block off the throttle? I only want to pressurise from air intake -> intake plenum (but not including the plenum)
I didnt block off the throttle.I just fit my pipe at the air intake then pressurise the whole system. Just rotate your engine till you find the sopt that holds pressure and pump away willis.
  • Nope 1
Uhhh........ please explain this? :)
Drivers side is almost finished, welding in shorts and singlet is fun, except for when you get sparks and burn a couple little holes in your arm. Hopefully will have the passengers side started tomorrow so i can get the car running again before thursday night
So it seems that big thick sound proofing/ heatsheild mat that sits on the fire wall doesn't like to be welded or to be near welding. Just had a minor fire
Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya?
i lost track earlier, what turbs did you end up going with?
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
