yer those camera's stand out pretty easy.
The song "theres a hole in my bucket" come to mind when i have pulled my car apart. Got the drivers side cleaned up and ready for metal to be cut out and new stuff welded in, passengers side is worse. This will take all week
is it an expensive exercise ?
Hahaha no thanks
Anyone have ideas for how to make a pressure tester for my piping?
I'm thinking PVC end cap, drill small hole in side, insert bike tyre air screw part, seal around the edges and hook up to compressor.
Replace AFM with this item and listen for leaks in piping??
Will PVC withstand 10psi?
It will work, i have one that I run off my compressor. Just be careful not to over boost it though.
Less likely with a pushbike pump thaan a compressor but meh!
  • Nope 1
Please note that A J Wyllie Bridge on Gympie Road, Petrie is currently closed to traffic in both directions. An alternative route is available via Youngs Crossing Road, Petrie.
Advice has been received from Main Roads that the lower bridge may be opened late this afternoon. This will carry one lane of traffic in each direction. They have also provided advice that the high (southbound) bridge will be closed for some weeks due to extensive damage.
Weeks! FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU
Time to find an alternative route to work...
Hahahahaha sweet... Yeah haven't decided if I'll use compressor or bike pump yet.
How did you block off the throttle? I only want to pressurise from air intake -> intake plenum (but not including the plenum)
I didnt block off the throttle.I just fit my pipe at the air intake then pressurise the whole system. Just rotate your engine till you find the sopt that holds pressure and pump away willis.
  • Nope 1
Uhhh........ please explain this? :)
Drivers side is almost finished, welding in shorts and singlet is fun, except for when you get sparks and burn a couple little holes in your arm. Hopefully will have the passengers side started tomorrow so i can get the car running again before thursday night
So it seems that big thick sound proofing/ heatsheild mat that sits on the fire wall doesn't like to be welded or to be near welding. Just had a minor fire
Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya?
i lost track earlier, what turbs did you end up going with?
    • Hi SAU family, having issues with my R34GTT which is slightly modified and tuned to e85. so scenario is, I’m driving the car to work (30km oneway) and then coming back in the arvo. Car starts and runs fine in the morning and on the way back home (in the arvo). I stop the car when i gets home and after 10-15 mins, it wont start. Battery is fine, fuel pump seems to be working. All i hear is engine clicks but wont start.  Last time, i disconnected the battery terminals and re connected them. Check fuses. Didnt start at that time but started after an hour (so I say when its cool down). Mechanic cant find the issue as its running now and nothing coming up in the diagnose. any advice,opinion or anyone gone through similar issue.   thanks 🙏🏻
    • 9" +35 will rub on the suspension. R33 GTR wheels are +30.
    • I know a guy with 18x9 +22 on the front of a 32 gtst, needed quite a lot of guard work, tyre stretch (215) and camber. Not sure what your current set up is, +35 won't be as much, but still a fair bit of guard work and camber.
    • Well as expected the ECU wasn't getting proper manifold pressure reading.  Once I switched to a 3rd vacuum line directly off the back of the manifold the car runs amazing.  Still slightly lean on full throttle but only like 15 AFR, probably fixable with some tuning.
    • Cliff's for those of us who refuse to even click a bookface link?
