Dan_B Posted January 17, 2011 Share Posted January 17, 2011 yer those camera's stand out pretty easy. The song "theres a hole in my bucket" come to mind when i have pulled my car apart. Got the drivers side cleaned up and ready for metal to be cut out and new stuff welded in, passengers side is worse. This will take all week Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628433 Share on other sites More sharing options...
Nee-san Posted January 17, 2011 Share Posted January 17, 2011 yer those camera's stand out pretty easy. The song "theres a hole in my bucket" come to mind when i have pulled my car apart. Got the drivers side cleaned up and ready for metal to be cut out and new stuff welded in, passengers side is worse. This will take all week is it an expensive exercise ? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628528 Share on other sites More sharing options...
FineLine Posted January 17, 2011 Share Posted January 17, 2011 Hahaha no thanks Anyone have ideas for how to make a pressure tester for my piping? I'm thinking PVC end cap, drill small hole in side, insert bike tyre air screw part, seal around the edges and hook up to compressor. Replace AFM with this item and listen for leaks in piping?? Will PVC withstand 10psi? It will work, i have one that I run off my compressor. Just be careful not to over boost it though. Less likely with a pushbike pump thaan a compressor but meh! 1 Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628553 Share on other sites More sharing options...
Smity42 Posted January 17, 2011 Share Posted January 17, 2011 Please note that A J Wyllie Bridge on Gympie Road, Petrie is currently closed to traffic in both directions. An alternative route is available via Youngs Crossing Road, Petrie. Advice has been received from Main Roads that the lower bridge may be opened late this afternoon. This will carry one lane of traffic in each direction. They have also provided advice that the high (southbound) bridge will be closed for some weeks due to extensive damage. Weeks! FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU Time to find an alternative route to work... Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628583 Share on other sites More sharing options...
Traditimeour Posted January 17, 2011 Share Posted January 17, 2011 Weeks! FFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU Time to find an alternative route instead of work... Fixed Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628602 Share on other sites More sharing options...
Smity42 Posted January 17, 2011 Share Posted January 17, 2011 LOL Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628612 Share on other sites More sharing options...
mosquitocoils Posted January 17, 2011 Share Posted January 17, 2011 It will work, i have one that I run off my compressor. Just be careful not to over boost it though. Less likely with a pushbike pump thaan a compressor but meh! Hahahahaha sweet... Yeah haven't decided if I'll use compressor or bike pump yet. How did you block off the throttle? I only want to pressurise from air intake -> intake plenum (but not including the plenum) Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628660 Share on other sites More sharing options...
Col-GTSX Posted January 17, 2011 Share Posted January 17, 2011 fk it is hot... pool time Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628669 Share on other sites More sharing options...
FineLine Posted January 17, 2011 Share Posted January 17, 2011 Hahahahaha sweet... Yeah haven't decided if I'll use compressor or bike pump yet. How did you block off the throttle? I only want to pressurise from air intake -> intake plenum (but not including the plenum) I didnt block off the throttle.I just fit my pipe at the air intake then pressurise the whole system. Just rotate your engine till you find the sopt that holds pressure and pump away willis. 1 Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628711 Share on other sites More sharing options...
mosquitocoils Posted January 17, 2011 Share Posted January 17, 2011 I didnt block off the throttle.I just fit my pipe at the air intake then pressurise the whole system. Just rotate your engine till you find the sopt that holds pressure and pump away willis. Uhhh........ please explain this? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628731 Share on other sites More sharing options...
Dan_B Posted January 17, 2011 Share Posted January 17, 2011 urgh, grind, weld, seal. Now i need to wait for the sealant to dry before i can primer it Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628741 Share on other sites More sharing options...
FineLine Posted January 17, 2011 Share Posted January 17, 2011 Uhhh........ please explain this? 0413 863207 1 Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628744 Share on other sites More sharing options...
Traditimeour Posted January 17, 2011 Share Posted January 17, 2011 Typical first casualties of the floods in VIC Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628763 Share on other sites More sharing options...
Smity42 Posted January 17, 2011 Share Posted January 17, 2011 Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628778 Share on other sites More sharing options...
Dan_B Posted January 17, 2011 Share Posted January 17, 2011 Drivers side is almost finished, welding in shorts and singlet is fun, except for when you get sparks and burn a couple little holes in your arm. Hopefully will have the passengers side started tomorrow so i can get the car running again before thursday night Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628915 Share on other sites More sharing options...
FineLine Posted January 17, 2011 Share Posted January 17, 2011 Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya? sorry smitty, no dice bud. 1 Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5628942 Share on other sites More sharing options...
Dan_B Posted January 17, 2011 Share Posted January 17, 2011 So it seems that big thick sound proofing/ heatsheild mat that sits on the fire wall doesn't like to be welded or to be near welding. Just had a minor fire Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5629008 Share on other sites More sharing options...
PWND Posted January 17, 2011 Share Posted January 17, 2011 Hey Noel, you wouldn't have any RB25 upgrade injectors you want to get rid of would ya? i lost track earlier, what turbs did you end up going with? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5629091 Share on other sites More sharing options...
Col-GTSX Posted January 17, 2011 Share Posted January 17, 2011 i lost track earlier, what turbs did you end up going with? circular spin'ie ones... did i mention it was hot? Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5629099 Share on other sites More sharing options...
Col-GTSX Posted January 17, 2011 Share Posted January 17, 2011 my wife just came into the study with a icy cold bourbon for me... shes the best Link to comment https://www.sau.com.au/forums/topic/261269-inner-west-crew-whoretown-toowongst-luciakenmoreindooroopilly-and-sometimes-sunnybank/page/1473/#findComment-5629119 Share on other sites More sharing options...
