my wife just came into the study with a icy cold bourbon for me... :D
shes the best
Mine is trying to get me to stop drinking them....
My weekly average is pretty high though, so proly for the best, and the cerb weight of 120kg fully laden is not doing me any favours
As i type this, i do have a wild the sphincter of the universe in my hand though.
hmm the sphincter of the universe
turkey....
odd. why can't you write turkey
im in the same boat, but she is encouraging me at the moment... maybe she wants something...?
Wanna swap. You give me a hand job and I'll give you a strong lemonade
sounds like a good deal... in prison Noel would be considered too generous...
Jim Carey?
WTF is with all that the sphincter of the universe stuff?? Lol
You had to be there bud. It was an ongoing thing in wasteland with barbarian and his love of all things the sphincter of the universe. aka. t u r k e y
  • Nope 1
@Miso, going to get a hypergear hi-flow when they re-open
cool. they seem to be making a good name for themselves.
will have to take me for a ride when you do get it. curious to see how it feels compared to my old high flow.
Morning Mangs,
My oil cooler came yesterday I think I got short changed on the hose lol but ahwell only got like 2 pieces 30cm long. But it has a shitload of earls fittings with it. BDO this weekend though so won't have a chance to fit it.
Work is doing a two week site release to help with the Flood cleanup so I'll be doing that for two weeks, should be interesting.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
