In news today, offically have been promoted at work to head lotus tech/senior technician, also been given a payrise.
Well done mang.
If you're allowed to say, what company do you work for?
Work for Euromarque Brisbane, have done for 6 years now.
Martin bit of a tough one there, Team Lotus or Lotus-Renault. I do prefer the Lotus-Renault for the traditional JPS colour scheme, will be a good year though for them, massive factory upgrade, new importer into the country (don't have to deal with proton anymore) and new models coming out, looks like i'll be a little busy.
Congrats.
Hahah yer scott i couldn't resist! i thought you would have been freaked out a little.
Pretty sure the brumby has broken something in the box, when you accelerate it sounds like a clicking CV, when cruising along it makes the same noise / bearing noise also but that all goes when you push the clutch in and coast along. So im thinking i'll get a good condition gearbox and a new clutch to throw in, i'll also replace the CV boots and inspect them for wear. Thoughts?
Yeah, had me wondering what was going on! A second hand box and clutch will cost you a lot less than a hilux or a WRX......The Brumby should keep on truckin' on when you have sorted.
Started off wiping/cleaning/polishing peoples tools and now he's been promoted to a glorified Coffee boy... :nyaanyaa:
BTW, which coffee shop do you go to??
/\ This
/\ AND this.
Glad that's sorted :D
McFly, all the fiddly bits are done on youe ECU now. Just need t ofit the chip socket and we're away!
I did find a 5 speed conversion on ebay, complete with tail shaft and rear diff for $595.... thinking i might go that way with it.
damn right!
hey jon you've got mates in the wrecking business, i need a dual range 4 speed gearbox for a 1991 subaru brumby. How much you think that would go for?
cant remember seeing 1 in wreckers for while but ill ask a mate of mine, his family repairs/builds subarus for a living mainly wrx's etc, he has a 2dr sti wrx and a brumby with twincam turbo motor.
worth a shot, has alot of old shitas laying around...
jon.
yer 4 speed with a hi/lo ratio is the normal thing for them, if you can find a 5 speed box i would need the gearbox, rear diff and tailshaft.
hurry up dent repair man, i have sleep to catch up on...
damn these 5am starts...
sick as a dog too... why is it so hard to get the good shit at the chemist these days...
i wasted $16 on some bullshit cold and flu yesterday and its done nothing, give me the farkin good stuff...
im not going to turn it into speed, i just want it cause it works...
i should take back the other shit and make them refund it, its shit...
Morning Mangs,
Road the bike into work. Didn't appear to take any less time but I did enjoy going to the front of the lights every time :thumbsup: So where is lazserhunt this week?
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
