Hard suspension, lots of negative camber, Mechanical diff and ages old rock hard second hand rubber is the formula for doing a fully sick skid bro
What qualifies as 'hard' suspension? Coilovers? Or could you get away with simply lowered springs + adjustable sway bars etc etc?
Probs going to head to BNR meet on thurs even though GT-R is sick.
I think they are playing electrophaggotry ( laser tag) instead?
Cool. I had never seen anything like it before, haha.
if you have adjustable suspension set your dampers in the rear to hardest and go for a drive...you will soon see how they do it!
Well I'm a fat bastard and fat bastards like me don't like to run so I might give Pew-Pew-Pew Starship Troopers a miss. However, I'm a fat bastard and fat bastards like me do like Ice Cream so I might come along later to BnR :P
Morning all.
Miso have you got names for them yet?
Pretty sure BNR is still on this week. Electrphaggotry is only for an hour or so and I think we'll be heading to BNR after that which will be around 9ish.
Hopefully I'll have my baby back from the guys at Fulcrum today. Will be good to not have it constantly bottoming out and rubbing on the guards every time I hit a bump or corner at speed.
I'll be at BnR around 9ish tomorrow. Hope to see a few of you there :)
sorry didnt see this here before
Coilovers with the dampers wound right down and very low springs would likely do it too, anything that limits travel and absorbing the shock effectively really.
Know much about fixing an effects pedal that won't power on?
It's a korg ax3000g
Dude those korgs are old! I thought my boss gt3 was the oldest thing around lol. Glad I sold that actually. Loving my podxt live :)
ANYWAY...... not really, short of checking/replacing the power supply you could maybe open it up and check around the power jack and the leads going away from it. That's easy enough to do.
Any more than that and I can't really help though :(
with fire
This is probably easier.
You can still buy them! It's actually a mate of mines, his ball and chain bought him another one cause this one was stuffed.
I would have personally bought something else but women, you know..
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
