btw... what does "too young" mean?? :huh: i confused...
It means I'm not old enough to not give a shit if people think I'm a creepy old man. Besides age = experience. My last girlfriend was 5 years older than me. Good times ;)
My last girlfriend was 5 years older than you too.
Big storm is big... Let's see how this goes tonight.
Better not be too big, I fly back into Brissy from townsville tonight, I really dont want that to turn into tomorrow.
yup, got one sitting in my shed
Thanks mang, already did a sweet deal with Ravi !
we didnt even meet in a carpark, so much more dignity on SAU as opposed to boost, haha.
Had to fly around for 30 mins before we could land, then wait on the ground for another 20 before we could go to the gate.
The turbulence was fun though. Ladies in front of me kept screaming, was funny as.
HAPPY f**kING FRIDAY!!!!!!!!
Well we could have if you wanted to? Hahahaha
WTF! What do you do? Is joo a pie-lot?
did they still serve booze? turbulance and drinking is fun
+eleventy. I hate flying, need to be drunk before I even get on.
(Someone please do a 'thats what she said' on that last part)
I saw a guy with a two tier umbrella. I was amazed, must be in the $30 category of umbrellas. I still managed to get half my arm wet though.
Busy weekend coming up, we should actually organize a steak night soon. Somewhere sort of in the middle of where everyone meets that has adequate parking and docks for ravi's boat.
LOL, no. I work with remotely read smart metering systems, have to travel around a bit.
Didn't get out of airport till 11pm last night, sucked serious balls.
TFIF
Please explain this two tier umbrella. I am intrigued.
It was basically an umbrella with another umbrella on top of it. It seemed to have a larger area of cover than your standard single tier umbrella.
Never been to German Club, ist gut?
I remember a flight i think it was either going to or coming home from un zud with virgin. Or it might have been perth...
Anyway, we scored the front row seats for more leg room (because the check in dude was hot for kyle), which as an added bonus come with a nice view of the hosties when they sit down.
It was a particularly hairy landing and sitting right in front of them we could tell the poor hosties were terrified, but trying so hard not to show it. It was hilarious.
Is joo a pie-lot?
I'll give you a pie lot.
I am intrigued.
That's what she said.
Ja, sehr gut. Ich trinke viel bier und essen große wurst.
Edited by Smity42
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
