Don't break your cars anytime soon.
Nissan Motor Co said it would resume production at its Kyushu plant on Thursday and Friday for as long as inventories of parts last. Other auto-assembly plants, as well as its Yokohama engine plant, will remain closed. Nissan did not disclose the number of vehicles affected.
Nissan said transmission plants were damaged and have stopped operations because of another earthquake on Tuesday in Shizuoka, southwest of Tokyo.
Read more: http://www.news.com.au/breaking-news/japan-car-makers-still-hobbled-after-quake/story-e6frfku0-1226023375131#ixzz1GpnIZbys
what's the headcount like for this afternoon?
I should be able to manage yet another one of my brief pit stops
Will be there for a similar pitstop.
I'm in for tonight. Probably walking however :( New radiator won't be ready for another week or so and after the radiator goes in it still needs to be sent to EFI for tuning so it may be two more weeks until I have her back. At least I should have a few more killerwasps for the hive with the intercooler and new ECU and it won't go boom with the PWR radiator :)
Nice!
I fixed it!
That's my days work right there.
Good shit bru.
Good Job, Team.
Mr Motorvation right here.
Thats what she said.
THat's what she said.
I like you, Noel
That's what Marty said.
fixed
AS in Neutered?? :blink:
They don't make parts for 31s any more anyway.
Nice!
Good shit bru.
That's what she said.
I now have a nice stainless dump and front pipe for teh stag.
Dump and front pipe
Bit eBay Spec, but it'll do for $120 :D
Doesn't look too bad :thumbsup:
Got the old lady out of horsepetal today so probably a no show tonight.
That seems like good news :)
Give my regards to the girls and tell them thanks for the mamarys.
Will do.
You think I sit at my desk with clothes on...
I think you don't have a desk and this is all a ploy to make us think you are someone important!
I knew as soon as someone mentioned 'that's what she said', you'd show up lol
You're right :(
It's really just a stainless table from IKEA. Looks like something you'd cut an animal up on :shrugs: Maybe I'm Brisbanes very own Dexter.
My ears where burning... What can I say!
Not the thighs of someone rubbing on them?
LOL.
Picked up some brake pads on the way home, putting them in on sunday. One thing to cross off the list.
Edited by hylian
One of the many pics of the Japan aftermath.
Not sure what the car was, but I wouldn't mind the brakes of it.
Will have to spend some time perusing japan auctions in the upcoming months :P
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
