he was flailing the whipper snipper around like thor's hammer, whilst swearing in german and occasionally yelling in a strong accent "DON'T EVEN THINK ABOUT IT" sounding like Arnie gargling roof nails.
Sig'd.
Sig'd.
no more sammich quote?
two was too much to ask for :P
paid for fuel this morning. 163.9 is an all time high that I have paid for the litre. just over $80 to fill the golf, and I am pretty sure the 32 is nearly out.
I paid the same last night...mega gayness
in other news
can some one open this link http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/190613_118765794865911_100001974734909_143505_436452_n.jpg
save the pic and upload it to this thread, work has all personal storage blocked and I am bored so I want to compare this dyno graph of -5 to my 2510s
sammich one vanished a while ago actually... it got too old :P
I have 3/4 a tank of stale fuel in the 31, should last until I get back from melbourne :). Will put fresh fuel in for the tune.
in other news
can some one open this link http://a2.sphotos.ak...05_436452_n.jpg
I saw that man, and Its a pretty nice power curve, but, I would say it's a little low. -5's are 720HP worth of turbo.
Interesting it makes 10- 15 more horse power every where until it pulled away right at the end. Running lots more boost though (about 7 psi more!)so that might have smothing to do with it.
Its probably not a terrible result for him, it was done at the same tuner as me and his dyno is a bit of a low reader...as evidenced by all the sad faces at the dyno day the club had there! lol
I think you'd be doing really well to get 600hp+ out of -5s. The highest I've seen is 430kwish which is about 560hpish? I want to see someone throw a set of those new efr turbos on a 26 or 26/30. Would be a bitch piping wise but I bet they would crank out some solid numbers with epic response.
yeah twins on a GTR never seem to be able to hit thier combined rating, mine are rated a 310hp each...but are no where near that, infact people are amazed that i made what I did at the boost level I am on so yeah my 620hp turbos are flat out making 450 at the engine
Yeah I don't think it's as simple as I have 2 x 400hp turbos so I should make 800hp. Either way -5s seem to be the go to turbo if you want 400kw and still keep the twins.
sadly there doesnt seem to a be a lot inbetween somthing for 300awkw like a GTSS/ -9/2510 or 400awkw like 2530/ -5...though it would seem like the 2530- -5 are quite capable of matching at least the 2510 for response so just running them at less boost could fill that gap
Yeah, Twins never hit their advertised theoretic and neither does a single, although it does come alot closer, there are always loses, heat,drive train etc etc.
Are you talking about mercury, I was there for that dyno day a couple of mates had their cars run up.
I made 431HP on R33 N1's on my 32 at ~17PSI I would like to make more then another 36HP with a few hundred horsepower more of turbo on board.
Not to take anything away from that result, because that thing would go like a bat out of hell !
My N1's are busted now (oil seals) so -5's will be going on and shooting for 400AWKW.
See how I go i guess.
Today I made Craig do work. Was lulz :cool:
Yes i did have to work hard for that lol. The strange thing is that you will get more $$ for that sale than i will lol.
400awkw seems to be on the really well sorted motors with all the fruit to back it up + running 25psi lol. Most results on the -5s are 340 - 380kwish and yeah the response is pretty good aswell. You could get -9s and run E85 and go for 350kw lol.
I think he is referring to EFI at Yatala. -5s will be sick.
just be sure to keep going back to the same dyno to measure differences
and don't be disappointed or disillusioned if the temps and humidity is different on different days
most dynos have compensation to power depending on weather conditions
to give you an example of how different dynos can read;
roughly same temps etc, just different brand/model dynos (GTST 33 GT30 @ 19psi);
Matt Spry = 312rwkw
Mercury = 336rwkw
Allstar = 301rwkw (with wheel spin)
Godzilla = 331rwlw
So it was impossible for me to tell how much power I was making as it depended on which dyno we used...
all i know is it was 300rwkw+ :D
Yeah i am considering E85 at some point. taking my boost up from 15psi and running E85 would get me pretty close to 350 as well i reckon!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
