I was fine when I was waiting for parts and waiting for them to be installed. It's knowing that it's all back together and all working and driving just fine (just not as efficiently as it could) that is killing me.
Well fret no more. They now have it. Not sure that it will be done today but it's turtle-heading
You just made my day Dan the man!
*Does a happy little dance*
Reckon I'd be fine to swing down tomorrow arvo to pick her up?
It's got a new Nistune ECU in it.
Good choice :thumbsup:
Nice power from a lightly modded 25 I must say :) I'm going to be happy if I get around 180-200rwkw.
Yeah really happy. People have got around 250rwkw @ 18PSI out of the same turbo, but probably have a less restrictive intake. Also i believe EFI's dyno reads a little on the low side. So I'm stoked.
So, seeing as it's driving so great, you going to come out for a drive to Jacks?
So I can hard park it? Negative. I've got to go round to Dave's to pick up a shroom for Scott, and help (read: supervise) Dan getting Dave's clutch working.
It does read a bit lower than most, at the majority of places around you would make 10 to 15rwkw more i reckon.
Don't think Dan can make it now. It's not like I need to drive the car to work tomorrow or anything :whistling:
Which would put it pretty much bang on that 250 mark :).
Roger. I'll swing round anyway and grab 'shroom.
Noel if you go to Jacks let me know, It will give me a good reason to clean my car
yup, no work again tomozz so Fat Alvin will be rollin in...Be hatin
Village square it's called. Enter carpark beside JB-HIFI.
I laughed fairly hard at the idiot who ripped the bottom out of his super low S13 about a month back. He tried to cone in over the big speed bump at the other side :P
hey does anyone have an r32 actuator (10psi) and if they want to give or sell (but mostly give) can they please bring it to baskins tomorrow? or a boost controller/ tap for the right price :rofl:
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
