Always had a soft spot for the old beetle. Had one as a paddock thrasher back when I was 13, 14. That and a ke70, sort of wish I hadn't put it in a dam now.
Col, never met but it's good to hear you will be getting a bit of money back. Sad that you worked hard over the past few and haven't gotten 100% in return, some people get it easy, the rest of us work hard for nothing. What Lexus did you get?
Edited by hylian
So I cant help but notice I don't understand....so........
sorry.. to hear it ... Col??
:blink:
its all good, i removed a post i made...
which explained where i was up too...
Yeah no complaints really, you get set backs now and then it will all work out in the long run im sure...
We bought a RX hybrid to go with my IS... We now have "lex'i" in the garage... All Japanese again, jap cars, jap bikes and jap powered gardening tools... :P
I was way off. I was thinking you'd get a 350 seeing as you wanted one last time.
I was heading down the ISF line, but Nay didn't want another V8... So i got her the hybrid instead...
270kw combined output (one petrol and two electric motors) and 710nm of torque @ 1920kg...
Its faster than any factory HSV/FPV out there at the moment and its an SUV... :D
Remember electric motors make high torque right from 1 rpm... So when you floor the pedal it launches like a modified GTR...
So i sorta won at the same time... No ISF but at least we got something as fast...
I'll be trading my 250 on a 350 or ISF later in the year... 153kw up to 233 or 311kw (budget pending) :D
Mangs, long shot but my better half is doing a cert 3 in admin, and wants to do some work experience. If anyone knows or works in a place that might be able to accommodate her for a day or two a week, let me know.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
