I bozzed in my pants, I bozzed in my pants.........I opened a window and a breeze blew in.......I bozzed in my pants, I bozzed in my pants.....
bwahahahahahahaahahah :thumbsup:
getting to work this morning requird a stop and rewater, but new hose fitted and seems to be functioning finerofl.gif
must get better wheels and tyres for next time!!!!
also are there gonna be pics up somewhere?
Edited by KRECHR
@John: GPS says I was doing a max of 190 :(. I don't think I trust it.
Also, you owe us some pictures ;)
that reminds me. I should look at Boz's one once I toss the screen back in. I bet it says the same if not higher.
Don't think I got it much past 170 or so down the main straight, will be curious to see what I actually hit. Was too busy looking at the track to pay attention to my speedo.
we will know on wed morn.. (hit reset on it as well ;) )
I watched your speedo max out and the rpms keep climbing. That last run down the straight felt like 210 to me.
I found out I don't have speed limiter cut on my car after my speedo hit 180 but I doubt I hit quite as high as 200. Didn't feel as fast as the pintara.
Pictures soon bro.
Can't trust a factory speedo anything past 100. Can't trust my speedo at all, its reads about 12% high at the best of times.
I would however be surprised if I was doing less than 210 in the sprint sessions. That run I took you on, that was probably 180-190 odd.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
