Ahh, one of them big magic fuses that actually supplies 12V hey?
yep.
been working on/off it for the last two weeks whilst doing other work. I now have 3 full days on it to get the battery moved properly. toss two battery disconnects in place (one drops the alternator inside the car.) take out the AC wiring, rewire the heater,rear demister and fix a lot of electrical niggles in it. right now I'm doing 0 AWG body earths on it using double jacketed flame proof wiring on the lot.
its a fairly full on job and I'm documenting a lot of it o camera.
And here I was all along thinking it was a battery that did that.
Where can I get one of these fuses Chris?
yep.
Sounds like fun. Keen for photos.
ppfffttt... batteries are so 20th century. Magic fuses are where it's at :thumbsup:
He's ok. Sore neck and collar bone but no visible injuries.
He's in a neck brace and on the magic puffer.
Car is most likely a write off. If Jeremy allows it can post some pics later.
Bags went off.
He was going straight, little old lady was coming the other way. Somehow failed to see him and attempted to turn right, right in front of him.
Don't think he even got a chance to brake.
Forgot to say, little old lady is fine as well.
Didnt see her before she was taken to hospital, but the paramedic said she was fine.
I have Jeremy's blessing, so will post some pics when I get home, 4ish
if he gets it back that will allow him to fix the cefiro :)
but yes that is definitely a write off.
Would be a pretty big job. n/a ceffy would have 4 stud hubs so would probably need to swap all the brakes and hubs out as well.
In the second shot you can see the ass end of the corolla wagon that the old lady was driving
forgot to take any photos of that, but it was worse off, with the whole front end completely crumpled in, with the windscreen broken, and the pillars creased.
Not sure,
I was taking photos of the car when Jeremy was talking to the cops
I could be putting words in his mouth, but I think he didn't even have time to brake, so 60ish, and probably 20 odd k's that she was doing.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
